Brake Pedal query.
Shivang, i have removed your model file from Forum. This is open forum & anyone can access your model file. In order to share your model file, Kindly share *.HM file to my drop-box - https://ftin.india.altair.com:8443/filedrop/~PfJQ9h
There are two ways to reduce the length of 3D Elements
1. For mapped geometry, you can simply enter the small size as compare to older size.
2. In Conventional Method, Mesh the geometry with 2D elements & with smaller element size by improving Quality Criteria , you can convert them in to 3D Elements.
In both the above cases, you should delete the old HEX Elements first.
In order to make the geometry Mappable , you can refer below provided tutorial.
For Making Mappable Geometry -
For Creating Hex Mesh with Mappble Geometry -
Thank You Sir
For your suggestion
