Hello!
My problem is, that I am trying to optimize a selfmade model. Some parts of the model should stay the way they are, because i need them for the intended function, therefore i created a second property which I called 'nondesign'. This worked well on previous models I worked on.
Now the problem is, these nondesign Elements end up just hanging in the air after the optimization.
Maybe I have some misconceptions over how the program works, but as the elements are reduced - i.e. the area nears zero - shouldn't the stresses go towards infinity? So shouldn't there always be at least some elements left?
But instead I'm left with the nondesign elements just uselessly floating in the air, with no connection to the mainbody whatsoever.
I have added some screenshots and the model for you to look at. The yellow elements are the 'nondesign' component.
I should note, the model is not necissarily realistic, especially the forces. I played around with some of the values to get a feeling for the model and to see how it behaves under different forces. So those might be a little unrealistic.
I hope someone can help me with this.
Thanks in advance.
The Model:
