Hi sir,
I am solving an exterior acoustic problem for a stator. I got an unknown error while solving it. The error pic is attached below:
Can you please share the entire .out file?
The '.out' file is attached below.
Hi Mayur,
Not sure if this is causing the error, I see a warning message
*** WARNING # 2841 In modal frequency response subcase# 1, the upper limit of loading frequency exceeds the upper limit of corresponding EIGRL/A data. This is not recommended
Please check the loading frequency and try again.
Sir last time also this warning was there but the analysis ran fine. This is some new error coming after increasing the sphere radius
OK then, I will check what is causing the error.
The model has been sent sir
You have a lot of loading and resvecs for those.
Please add “RESVEC(APPLOD)=YES” and try again
I ran the analysis including RESVEC(APPLIED) =YES
But i am getting similar internal programming error. The '.out' file is attached below.
Please help me on this
Mayur,
I have shared the files with experts and waiting for their feedback.
OK sir, thanks a lot
Sir anything on this?
This programming error is fixed in 2017.2.3 update
If this is the setup you want, delete infinite element in the curent update and try again
Is it desirable to solve the analysis without infinite elements?
Do we need to use infinite elements or not sir?
for time being yes. 2017.2.3 is not yet released and may take few more weeks.
it would be better to if you try with Infinite method.
Will the problem be resolved in HW 2017.2.1?
No, maybe in 2017.2.3
Is HW 2017.2.3 released yet? Because I can't seem to find it
We will let you know once it is available.
