I'm trying to do properties calibration with Hyperstudy.
- I have an ortotropic material with 9 properties to be adjusted
- I want to change properties in a way that the frequency of an specific mode changes to a target value.
- The problem is: The modes are changing positions
- The possible solution is: Use modetrak to follow always the same mode
- 'Param, modetrak' is not working -> What should I do to fix it?
