knuckle simulation
Altair Forum User
Altair Forum User
I am doing a component level analysis where I don't have knuckle assembly. I just have knuckle. I have doubts regarding SPC. Should I apply spc on caliper mounts on knuckle? Also  there are four bolt connecting knuckle with the dust cover. Should I constrain those or just constrain the suspension mounts?
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Hi Alekh,
    I presume you don't have the caliper mount component and the Knuckle would sit on this caliber.
    if yes, you can constrain the nodes of the Kunckle which sits on the mounts using SPCs
    The better way to model the bolts in the assembly is to tighten them by pretensioning analysis.
    You can apply bolt pretension in OptiStruct and make the cover come into contact. Else, you can just define a FREEZE type of contact between the cover and bolt head
    Let is know if you need any further information
    Thanks,
    Vikas
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Sir I don't have any other component except knuckle so, I cannot define contact so should I apply spc on calliper mounts on knuckle and also on dust cover mount on knuckle?
  • Altair Forum User
    Altair Forum User
    edited May 2017
    Yes, please constrain them using SPCs
    Thanks,
    Vikas
