Dear All,
I need the model on this link http://www.altairuniversity.com/analysis/structural/nonlinear/compression-of-a-rubber-spring-nlgeom/, because the link to download is broken.
Thank you,
Best regards,
Iron_Man
Please find the model file.
Dear @George P Johnson,
Thank you very much
Hi, i need to perform FEA analysis over rubber seal in car door panel..Is there any guide lines or tutorials related to it..
Can you please elaborate on the objective of your analysis so that we can guide to a similar tutorial or example in our Learning Library.
Hi George,
To determine sealing pressure and stress of it, due to force applied from door closure...
Rubber component seams to be complicated,as it has many cuts..We are trying to perform hexamesh...Can you share ur mail id ..i will share the snap of the rubber component as it is confidential..
We have a similar kind of example available in our Learning Library, Door Slam using RADIOSS. We have used Ogden material here for rubber and you can review the same.
You can download the model file and also the presentation at https://altairuniversity.com/learning-library/radioss-door-small-example/
George...Thank you so much...yar
