Hello Sir,
I am modelling a manifold which looks like in the attached picture. In the inlet I can give my flow rate as boundary condition but the branch(one outlet) needs to be modelled in such a way that it exactly receives 1 lit/min and that flow will join after my restrictor. How should I do that as the outlet boundary condition in acusolve is relative pressure.
So here in my case I have two inlets and two outlets. If you can give me a hint to proceed it would be a great help.
Thank you
Prithvi
