I have query regarding admass.
I wanted to assign the mass to a plate which is rigid.
In this case,applied the mass at the master node of rigid body.
Query is that,what is the element type while applying the mass at rigid body master node and is it distributed uniformly along the plate?
Kindly suggest the solution.
Thank-you.
