I am trying to do the analysis but in the result panel, it is only showing the result on NON-Design space.
And both design and non-design space are not connected.
How to connect both of them.
Sir,
please reply ASAP.
we have solved similar query regarding 'Connectivity Issue' Kindly refer below provided link -
http://forum.altairhyperworks.com/index.php?/topic/20044-aoc-pedal-optimisation/
For Further help, you can share your model files through my drop-box link. Kindly do not share your model openly on Forum as this is open Forum.
we will go through the same & suggest you the changes, if required
For AOC related , you can write your queries to Forum for India Academic Users and AOC India Participants for faster reply.
