Compliance value
Altair Forum User
Altair Forum User
My name is Michal,
I would like to ask you how can I understand value of compliance in .out file of the optistruct?
If i understand compliance correctly it is displacement of the object when a unit of force is applied.
In my model I have mm, N, MPa, kg as units, but value of compliance of my model is 3e03, epsilon equal 5e-011.
And the model is definitely not deforming by 3 meters while 1N of force is applied.
Do I misunderstand the compliance or its unit? How to transform it into stiffness- normally it is 1/C right?
Best regards,
Michal
  • Altair Forum User
    Altair Forum User
    edited February 2018
    Please, could you help me?
    I want to compare different concepts between each other and using this value would be very useful : )
    Best regards,
    Michal
  • Altair Forum User
    Altair Forum User
    Hi Michal,
    Compliance is calculated as:
    Where f= KX
    Compliance is a direct measure of stiffness for a structure with an applied displacement is constant.
