Hey,
how can I extract COG, Moment of Inertia and Mass as an output by running a static solution in optistruct?
Thank you in advance.
You can get these infos by using hypermesh panel post>summary
Browse for some template files in os summary folder
Hello Tinh,
thanks for the quick reply! I can do that, but I need to get them as output of the simulation. Is there a way of doing that?
I think yes
Try searching an output card in os reference help
hello tinh ,
I am facing a problem in assigning names for my geometry . is it possible name surfaces in hyper mesh, because I need to import my mesh file in Ansys-fluent where I can't name surfaces in the imported mesh. i tried creating components and then-organizer-components-collectors-surfaces-destination(my name)- move. but then on the left bottom, a notification is coming like ' organize entities'. can you please help me to find where I went wrong. I am just a beginner in the hyper mesh.
hello tinh , I am facing a problem in assigning names for my geometry . is it possible name surfaces in hyper mesh, because I need to import my mesh file in Ansys-fluent where I can't name surfaces in the imported mesh. i tried creating components and then-organizer-components-collectors-surfaces-destination(my name)- move. but then on the left bottom, a notification is coming like ' organize entities'. can you please help me to find where I went wrong. I am just a beginner in the hyper mesh.
Sorry, i don't understand what you're saying
sorry for the inconvenience.
I am facing issue while naming the surfaces for further solving in Ansys. after meshing the surfaces, I have to assign boundary conditions to the surfaces . for example a wall, inlet, etc. how can we do that in hyper mesh
I think yes Try searching an output card in os reference help
Hi Tinh,
Thank you once again but I cannot seem to find anything that will output everything I need... The K, M and V matrix are not a problem, but I would also like to get the Moment of inertia tensor, the COG and the total mass as output. Is this possible?
Thanks!
Hi Tinh, Thank you once again but I cannot seem to find anything that will output everything I need... The K, M and V matrix are not a problem, but I would also like to get the Moment of inertia tensor, the COG and the total mass as output. Is this possible? Thanks!
Hi @MMarzana
Please add MASSPROP and check if that helps. Go to Control cards>> OUTPUT>> MASPROP to output CoG and MoI based on properties.
