Oscars
Altair Forum User
Is there a simpler way of adding Oscars in a model scene then making a surface in the same shape as the image cut out and adding a UV label to it? Also how would you add a plethora of tree images to a scene? Do they all have to be placed on a surface?
The image example is from Zaha Hadid.
Hi Joaquin,
Sorry for missing this post. I am not sure if you still have this requirement.
- I am not quite sure about your first request regarding Oscars. If you want to edit the shape of a surface using an Image, use the Pixel Map tool
- You can use the replicate tool to place trees on either a surface or a path curve (if you want to randomize them using several curves placed randomly). The replicate tool cannot randomize the input (not at the moment)
