hi,
i can't seem to get the T01 file for the output block i defined in hypermesh, does someone know what the problem might be?
Hi Phil,
XHIST is supported only for Geometric Nonlinear Analysis.
Which load step are you trying to solve?
Thanks
Vikas
How to give REACX , REACY in xhist for a node like we give in radioss. I am not able to find the same.
Thank you
Hi Gopal,
REAC forces can be requested on nodes using REACX/Y/Z
Please refer to the picture below
I have gone through this information was not able to see where to enter REACX , REACY variable for output in the attached image.
Can you please add REAC# through text editor to input file?
I am unable to open the FTP link. Could you please share the file again.
