Hi there,
I have an issue with the latest Radioss v12.
I am doing analysis on compression spring using radioss block100 format. My model involves shell, solid & rigid elements as well as contact type 7.
My problem is towards the end of solver run (spring is getting compressed) i get an increasing energy error (till 99%). This is only happened when i use Radioss v12, whereas Radioss v11 wouldn't give me that problem. Can someone clarify me on this?
p/s: I am using the AMS option for time step in bpth solver version.
Thank you in advance.
mfg,
Saifulss
