I just got into Altair Embed and I have encountered a problem. Whenever I try to download the already generated and compiled code into my Launchxl-F28069M it sais 'Target open failed: check config for correct target number'. I will post a picture below with my config and model. Even a little hint would be appreciated! Oh and also, I need to mention that I have all SW1 set to ON to enable JTAG comms.
Thanks in advance for everything!
Quick edit: I just tried to run this model in interactive mode, and got an error that said something about there being no JTAG communication. How can I make sure I have a solid communication? (via USB). The error was: Can't open target. Check: 1. Power to target 2. JTAG connection 3.JTAG driver selection in target config
