Hello sir,
sir i am trying to simulate one problem in radioss in which a bird hits a glass plate but i am not getting any result.i am attaching .hm file please help in in solving this problem.Thank you
monu kumar
Hi Monu Kumar,
Please check your parameters for the glass material. You have defined the failure parameters also for the material card. Please recheck and ensure the material values are correct.
Yes sir i have checked it its is correct
Hi Monu,
Try with the model file attached. Please note that I removed the failure parameters from the model and also remodeled the bird structure.
Thank you sir. thanks a lot sir . can you please share .hm file in which you have made changes and solved.
Please find the attached .hm file.
Hello George sir,
I am unable to open this file
Try with the attached file. If it's not working, please import the model_0000.rad file attached in the above post.
sir when I opened it in hyperworks14.0 some data has lost and the file is not running.and when I imported model_0000.rad and run that then it is not showing any result
see the results what i got
Please run the model with the engine file attached and then we will review the results.
