I have a problem if I set bolt pretension force on three bolt and I want to output their force (at Bolt.fem)
I have open the control cards > GLOBAL_OUTPUT_REQUEST > PRETBOLT like the photo
why it doen't have the pretension reaction force at the .h3dfile?
and I have 2 another question
1. If today my model have a lot of face to need contact. Does Optistruct has the instruction to automatic define all the model's contact surfaces? If I just set a slave contact surface it will automatic to search which face will contact with this slave surface (Like LS-DYNA single surface contact)
Is like this?
if it's it I want to ask what si Vicinty tolerance and Reverse angle suggest value
2. At the rigid setting, if today I want to set the part to be rigid and set the revolute joint. I set at the model is wrong and I can't know its wrong (I can use RBE2 to do and now I am trying to use rigid part)
*** ERROR # 2975 ***
The RBODY with reference grid ID 3836 is constrained by more
than six degree of freedom. This is not allowed.
*** Run terminated because of error(s) in the input data.
