I am trying to create a flexible lower control arm using the FlexPrep utility tool in 2017.2 student version. I am facing the following issues:
1. 'Create RBE2 Spider' tab not active, hence I am not able to switch to HyperMesh to create a RBE2 spider whose center is one of the interface nodes.
2. As a workaround, I manually created the RBE2 spider in OptiStruct and exported the solver deck as a *.fem file. When I try to use this file for creating a flexbody. I am getting an error.
I have pasted a snapshot of the flex prep utility and the error message when I try to generate the flexbody below. I have also attached the *.fem file and *.out file
Please take a look and let me know how this issue can be resolved.
