hi,
i did a spring modelisation between body meshed parts and i simulated a static analysis, and it gives as a warning 'compliance is negative or large 4.54e+11 compliance'.
what should i do to fix this problem ?
Hi @riham1994
Can you check whether boundary conditions are modeled properly?
Constrain in all directions and check if this gives any good results.
