what is the main difference betweeen rbe2 and rbe3 1-d connector?
In short:
1-D/connector/seam
a) I want to transform load and displacement from one component to other as shown below without any input property.
in seam weld which type should be prefer.?
b)also in 3-D both the component having a surface contact because of mid-surface there is some gap is obtained between these two component. Is there any need to give contacts between these two components.?
In short: RBE2 = a rigid element which adds stiffness RBE3 = an interpolation element used to distribute mass and loads
Thanks
