Hello everybody
Does anyone can help me to do transient analysis using tload1 card?The time history response result is infinity. I try to do the same way using tload2 and its works. Anyone has idea??
Regard
PFA example for TLOAD1.
Thank you very much for your response
How to open that file? In transient analysis, I used transient (modal)
regard
Its a optistruct solver deck file.Go to file : Import :solver deck:set File type to optistruct
Ok thank you very much.
But I think it similar with my analysis work. Here is the result of my works using transient modal. The load applied until 2 second but after that the response is infitnity. Do you have some idea??
could you share out file of run?
Here is my outfile of run
I dont see any Tload enteries in out file?Could you share .fem file aswell.
here is the fem file
so....do you have an idea about the fem file??
Hi Hidayat,
is there any damping specified to your structure?
I used structural damping for the structure
Did cross check the mass? What unit system you are maintaining in your model?I see youngs modulus of eardrum is low.
