Connecting two solids via CBush
Hi together,
I try to connect two solids via Cbush Spring-Damper Elements. Unfortunately the connection between the solids doesn' t seem to work properly. When i set the K properties to rigid, they doesn t work as rigids.
I tried to connect them over two very thin shell meshes one the surface of each of the solids.
Do you have any idea why this happens?
Is there a better way to connect two solids via cbush?
Attached you find the File
Thank you for your help!
Sebastian
If you have a negligible shell thickness, you will have nearly no bending stiffness so at the ends of the bush element you will have a hinge.
If you increase the thickness of the shells the bending stiffness increases, you are getting more and more rotational stiffness for the bush to connect to.I recommend to use a RBE3 element to distribute the load from the bush element to the volume elements.
0 -
Thank you for your reply.
Is it also possible to connect the two solids elastic using a contact?Therefore we need to manipulate the non linear spring, which is responsible for the transverse frictional force in a way to produce a force without having a corresponding normal force?
Best Regards,
Sebastian
