Hi guys.
I have a problem with the mat/law60. I launch Radioss, but it generate an error in the file .out
I have defined three functions for three strain rate.
Could somebody help me with this error?
Thanks.
Hi Javi86,
Please refer a stress-strain function in MAT/LAW60.
A stress-strain function is the follwing:
Did you referenced the same curve in LAW 60 material card?
the error says function is not referred in the material card.
Yes, I have referenced the three function in LAW60 material card.
The error is solved. MAT/LAW60 need four functions minimum to run correctly. Thanks for your help.
