I want to perform a topological optimization of a part to minimize its mass, with a given constraint on the compression stiffness along a single direction. I’ve tried to turn this stiffness constraint into a compliance constraint, without results.
My questions are :
Is there a way to create a constraint on a compression stiffness along a single direction ?
If not, how can I turn correctly this compression stiffness along a single direction into a compliance constraint ?
Thanks
