As you know, one of the most important issue in additive manufacturing is "Enclosed Voids" due to trapped powder and supports.
I think these issue can be prevented in a topology optimized design with split draw constraint.
My overall question is what should be the draw directions in a design which will be manufactured with SLM? i was applying the directions accordingly build orientation but i'm not sure it is correct or not.
I would be very appreciated if you reply my question and i can read papers you will recommend.
