Hi everyone,
How can i see the shear forces on the spring used as a bolt in my model ?
Thanks in advance.
If you are using Type 13 spring (/th/Spring) for Radioss solver then Fy and Fz will be shear forces.In HG load h3d file of the run and plot Shear forces.
Hi Rahul,
Even if orientation of the bolt changes, is y and z always shear force ?
If you are using Type13 spring then yes, Y and Z will be shear force because Type13 spring works in the local coordinate system. So node1 to node2 will always be X axis.
Note: Type13 spring for Radioss solver.
