Good Evening,
I have completed a topology optimisation and I am happy with results but now I want to to re-run the analysis.
I open ossmooth, load the model and results, use 'keep smooth layer around' and remesh using a 'mixed' mesh type.
I then go to run the analysis (-optskip) and I get an error message regarding compliance.
I don't understand what's causing this as the loads and constraints are all attached to the non design space. Is it a mesh issue?
*** WARNING # 312
In static load case 1
the compliance is negative or large 3.974381E+11
Optimization/buckling analysis cannot be performed
due to possible rigid body mode
*** WARNING # 312
In static load case 2
the compliance is negative or large 1.253294E+12
Thanks in advance for any help, this forum is an excellent resource and has got me this far. I just need a little help with this last step.
Kind Regards,
Mike
