I am doing a very simple pipe flow analysis, and I am getting an eratic results of pressure in Acufield, but for the same in Acuprobe it was giving quite accurate results. Why??
The pipe is 25m long with 10m diameter.
In Acufield I have defined the formula as:
Dynamic Pressure = 0.5*1000*velocity_magnitude*velocity_magnitude
Total Pressure = 'Pressure'+'Dynamic Pressure'
I have attached the .acs file and all the images for Pressure(Static, Dynamic and total) and velocity magnitude.
