Please specify the setup for imposed displacement calculation in Optistruct.
raj
You can impose displacement using SPCD,
Please refer to this forum post:
https://community.altair.com/community?id=community_question&sys_id=5376483a1b2bd0908017dc61ec4bcb0f
Hy,
I want to know from where we should provide the displacement value, is it in SPCD only with different direction or in some other load type constraint.
Rajendra
Hy, I want to know from where we should provide the displacement value, is it in SPCD only with different direction or in some other load type constraint. Regards, Rajendra
@Rajendra Prasad
Go to Analysis page>> Constraints>> Change load type to SPCD and activate the direction in which you want to apply imposed displacement and provide the magnitude. Constrain the same node with SPC.
If in place of displacement, I want to apply velocity, acceleration, force, etc. Then what is the procedure?
Regards
