Hello Sir,
I am simulating pipe flow using spallart allmaras model but the output i require is volume averaged kinetic energy of the flow. Since k-epsilon model can't be used in acusolve. How can i solve for my required output through spallart allmaras model. Also i have no clue how to define the physics behind the problem to get the required output. Can you please make some time to answer this and help me.
Thank you!!!
