Define surface in /EBCS (Elementary Boundary Conditions) CARD
Create a set with card image as SURF and recall the same in Surf_ID option in /EBCS.
If the issue persist, please share the model file through the secure dropbox.
0 -
I've still problems: I sent you the model file as you said.
Thank you
0 -
The corrected file has been sent to you.
0 -
I tried to run the simulation, but I got this error:
MESSAGE ID : 44
** ERROR : ABNORMAL END
| Segmentation Violation |
| TRACE BACK : |
ERROR TERMINATION
Attached you can find the engine file.
Thank you for your help.
0 -
Please share the starter out file (_0000.out).
0 -
I sent you the starter out file by secure file dropbox
0 -
The starter out file looks fine and there are no errors listed also. Can you share the model file so that we can run and review.
