How to output element stiffness matrix to ASCII file in Optistruct
Hello everyone,
I’m beginner in use Optistruct and currently working on solving a static linear elastic problem. I’ve been trying to find a way to output the element stiffness matrix to a ASCII result file. Could someone please guide me on whether this is possible and, if so, provide instructions on how to achieve this?
Your assistance would be greatly appreciated.
Thank you in advance!
Anoop
Hi Anoop,
Please try using the OUTPUT,MATRIX card (OUTPUT,MATRIX,REDUCED if reduced format is desired) to obtain the mass and stiffness matrices in ASCII format.
Thank you very much,
Robinson
https://help.altair.com/hwsolvers/os/topics/solvers/os/output_io_r.htm?zoom_highlight=output+matrxi
Hi Anoop,
Robinson
Dear Robinson,
I am using, successfully, the OUTPUT,MATRIX,FULL,SPARSE to output the stiffness and mass matrices, however, when it comes to the mass matrix, it omits the rotational inertia of the nodes that have 6DoF (corresponding to shell elements). Do you have any idea why this is happening and/or how to solve it?
Thank you very much.
Best regards,
Pedro Millan
Hi Anoop,
Robinson
Hi Anoop,
Robinson
