Dear sir,
I want to analyse a model in radioss implicit which was ran in abaqus for vertical loading (non linear static problem with contacts), what are the basic implicit cards i should use to perfrom non linear implicit analysis (with vertical loading of a plate on roof structure and type 7 contacts , elastic - plastic material also) in radioss and compare the results with abaqus. Is there any tutorial which have executed the run in radioss using implicit cards.
Thank you.
