i have a little question about the possibility of time scaling and the use of the radiation load collector.
I used the factor 10 (1sec in simulation=10sec in real time) to speed up my thermal analysis with radioss.
It works fine wenn i scale thermal conductivity and the heat transfer coefficent (for example convection) by the factor i used for speed up (10).
Is this although possible for the radiation? Because i don't see any way to scale this value in correct way...
With best regards
Kintsch
