Hi guys how do I open a acusolve model in hyperview?
The simplest way is to use the AcuSolve results direct reader in HyperView. Set the 'Files of type' to AcuSolve Result Reader (*.Log) and select the AcuSolve .Log file for the run whose results you wish to load.
cheers @acupro
