In addition to my previous post regarding saving a file, I am now having trouble saving and re-analysing a part.
I have optimised a design, and analysed it using the shape explorer function. The minimum factor of safety is 1.5. I have then used the 'fit' function and re-analysed using the same load cases. The minimum FoS then rises to around 7.
I am very confused as to why this is doing this.
My plan is to optimise, fit, re-analyse to check the results correspond and then run another analysis on the part to ensure that it can cope with another set of independent load cases.
Can anyone help with this?
Thank you
