Referring to community post FAQ - Verify or change the Java JRE / JDK version (altair.com) I am looking for answer to my question. If there is a possibility to disable java installation during silent mode installation?
Is there a switch that would do the same as unchecking the visible installation of embedded java? I need this to propagate the installation using SCCM without embedded java.
Answering for myself, I decided to remove the “jre” folder/directory in Workbench after installation and add the Open JDK installation as required in sccm. I then configured the workbench.ini file to point to the correct location.Like as here FAQ - Verify or change the Java JRE / JDK version (altair.com)
