zero result
hi
i try to calculate displacement and stress for this structure http://cjoint.com/?ECfxloSZeoh
i dont have an error but Hyperview give me every time zero for displacement and stress
i think my error is in my mesh i mesh this structure with tetramesh solid volume tetra
some one can help me to rectify my error
thanks
Looks like there is no load/force going on the structure.
Please check this.
If you have any temporary nodes, delete them and re-apply loads on the structure and check if you see any result.
0 -
There is a temp folder for tetras created, which means there are areas where there is no mesh.
Make sure there is connectivity across the entire model, using tool > edges.
Make sure the model is sufficiently constrained as well, make sure the force is of the correct value and in the same units as everything else in the model.
