How to model foam material and what type of analysis should be performed?
Altair Forum User
1. Can I do this analysis with optistruct, Geometric non linear analysis(impl static) ??
2. What kind of material should I use for the foam. The foam is Density Polyurethane foam. I don't have the stress strain curve yet but the customer is going to provide us the curve.
3. I have another question regarding the screw attachments. May I use two RBE2, one for outer surface of screw and one for the inner surface of the hole (use the independent node of one of RBE2 s for defining the second RBE2) is that correct?
I appreciate your help in advance
You can use MATX70, MATX33, MATX21 for Polyitherane foam.
3) Yes you can use RBEs at the top and bottom surfaces for Screw/bolt attachments.
