I'm using altair hyperworks 11.0, i had updated the software to 11.0.130.
Can anyone help me how to create engine keywords?
Hi Violla,
Can you check for the engine keywords in the control cards?
I think in Utility menu you will get a widget for creating engine keywords. I'm attaching a video which shows creating engine file in HW 11 version. Please go through the same.
PS: This is an old version of HyperWorks. I recommend you to go for the latest version, HyperWorks 2017 which has many features.Please go through http://www.altairhyperworks.com/hw2017/ for more.
Hi George,
Thank you for your prompt reply.
I had check the engine keywords in the control card but couldn't find.
Below image from the utility menu, but there is no engine file that i want to use such as /IMPL/NONLIN/n, IMPL/DT/n, IMPL/NONLIN/N engine file for implicit analysis. <?xml version="1.0" encoding="UTF-8"?>
As I stated before this is an old version, and I don't have this version to check these options.
i'm attaching an engine file with implicit keywords. The possible workaround is open this engine file in Textpad, copy these engine keywords, manually add these to your engine file. And make the necessary edits for the keywords in the new engine file.
Alright George, i got it. Thank you for your reply. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
