Hello experts,
I am performing a simulation in SimLab that is connected to Inspire. In the following picture, you can see the solid I am using and the parameters I used to draw it.
My problem is that when I try to export this solid to SimLab, Inspire stops working, as shown in the following video.
I must add that this step is crucial because, without it, I cannot continue with the simulation, as I need to conduct a study with that simulation in HyperStudy afterward.
I already solved this issue once by uninstalling, deleting some folders created by the installed Altair programs, and reinstalling them. This connection worked for two weeks, but the same error has occurred again. Additionally, these programs are installed on a university workstation, so repeating this process is very time-consuming.
How could I solve this problem definitively?
