Hi all,
I want to set up contact between two bodies in optistruct for modal and frequency response analysis, but I don't know how to do it? Is there any example for reference the detail process?
Thank you
Best Wishes
Roy
Anyone can help?
Hi @Roy Duan
What type of contact are you looking at?
Modal/FRF analysis are linear dynamics and contacts are non-linear which may not be compatible to the analysis type.
Hi @Roy Duan What type of contact are you looking at? Modal/FRF analysis are linear dynamics and contacts are non-linear which may not be compatible to the analysis type.
Hi Prakash,
As you said, the modal/FRF analysis are linear dynamics, so the contact may be tied I think. How to do this?
Hi Roy,
Yes you can try freeze or tie contact
Hi Roy, Yes you can try freeze or tie contact
But I don't know how to set up contact in optistruct.
Please refer to this tutorial in which creating contacts is discussed.
