Error 886 & 510
Hi, I am unable to understand this error.
Please suggest the proper solution.
.. SURFACES
.. NODE GROUP
.. BOUNDARY CONDITIONS
.. ALE/THE TABLES
.. IMPOSED VELOCITIES
.. INITIAL VOLUME FRACTION
ERROR ID : 510
** ERROR IN INPUT LINE
DESCRIPTION :
-- LINE : /INIVOL/0/4
INVALID IDENTIFIER VALUE 0 (OUT OF BOUNDS)
ERROR ID : 886
** INPUT ERROR IN INITIAL VOLUME FRACTION
DESCRIPTION :
-- INITIAL VOLUME FRACTION ID : 4
-- INITIAL VOLUME FRACTION TITLE : water
PART ID=0 DOES NOT EXIST
ERROR ID : 510
DESCRIPTION :
-- LINE : /INIVOL/0/3
ERROR ID : 886
DESCRIPTION :
-- INITIAL VOLUME FRACTION ID : 3
-- INITIAL VOLUME FRACTION TITLE : air
ERROR ID : 510
DESCRIPTION :
ERROR ID : 510
DESCRIPTION :
.. DOMAIN DECOMPOSITION
.. ELEMENT GROUPS
.. INTERFACES
ERROR ID : 612
** ERROR IN INITIAL PENETRATION IN INTERFACE
ERROR ID : 612
ERROR ID : 612
ERROR ID : 612
ERROR ID : 612
ERROR ID : 612
Hi Sachin,
looks like there are modelling issues in your model. Please check whether the material is compatible with property and element type.
Also, remove penetration as much as you can.
0 -
Hi Sir,
I am still getting the same problem.
Herewith shared the model.
Request you to check the model and suggest the proper solution.
0 -
I hope you would have cleared modelling error and continuing communication in negative rho error post.
Regards
Rahul R
