Hi all,
I'm a student, we have started using Hypermesh some months ago. I'm analyzing an earth moving machine's part. I have imported step which is composed by about 10 parts. These parts are in contact between them (slave or freeze). For accuracy reasons I used boolean operations ( {A-B, B}) to make mesh continuity between parts in contact. After that, I finally got a continuous mesh but Auto Contact tool is not able to find contact between elemens. It looks like, using that particular boolean operations, A and B are in a freeze contact, but I need to use this particular contact only for weldings so in some cases A and B can be in a slide contact between them. Can someone help me? Thank you!
I've attached the Hypermesh model if someone wants to have a look to it:
https://www.dropbox.com/s/qthyzxi8ebj3i4p/4.hm?dl=0
