PolyNurbs surface quailty
Ari Salonen
Ari Salonen Altair Community Member
edited January 2024 in Community Q&A
Is there a setting i should modify to make the surface quality better on a polynurbs object?
Now you can see that in a silhuette line and in a part line there are problems. Also production engineers say that this surface is not good enough. I have tried to keep the surface as simple as possible and made sure that surface faces have four corners.
Or is it so that these polunurbs are not meant to be production quality surfaces?imageimage
  • Ari Salonen
    edited January 2024
    Or is there somewhere a guide/video for using polynurbs to the production?
    I have to say that in many cases it is a real pleasure to use them.
