I want to show contour of temperature in such a way that. Temperature above certain specific limit should be transparent.
Ex: If a component showing Temperature max & min is 300'C & 90'C. The contour is set from 100' to 90'C. So, temp above 90'C will show red in colour. But in place of red, I want transparent (Invisible or white).
Simply I want to edit contour. And I don't know the procedure
