I am trying to set up a sort of indentation test. I have an indenter with a round tip, which will be indenting a specimen that is split in two as seen in the attached picture below. For the sphere - specimen contact I am using a type7 contact which is fine because there is a small initial gap between the indenter and specimen pieces, however, for the contact between the two specimen pieces, I have tried with type7 with inacti = 6 and tried again with inacti = 1. inacti = 6 gave penetration errors, where inacti = 1 gave penetration warnings. I also tried with Type3 contact but I got some element deformations that shouldn't have occurred. Therefore, for this situation would Type3 or Type 7 be better, and how do I go about getting rid of the initial penetration errors? And do I need to set-up a contact group from Specimen1 to Specimen2 and then another as Specimen2 to Specimen1 or would a single contact group take care of that?
