Problem with Altair Basic FEA
User: "Altair Forum User"
Updated by Altair Forum User
I have the following problem. The first error massage appears at the start of program:
list element in quotes followed by 'nur' instead of space
    while executing
'llength $pairs'
    (procedure '::msgcat::mcmset' line 4)
    invoked from within
'::msgcat::mcmset de {
        'Rigid Body on Lines'                     'Starrkörper auf Linien'
        'Rigid Body on Surfaces'                  'S...'
    (in namespace eval '::b3d' script line 205)
    invoked from within
'namespace eval ::b3d {
        'Dimension Mode'                          'Vermessungsmodus'
        'Material Database'     ...'
    (file 'C:/Program Files/Altair/14.0/hm/scripts/BasicFEA/languages/de.msg' line 2)
    invoked from within
'::source -encoding utf-8 {C:/Program Files/Altair/14.0/hm/scripts/BasicFEA/languages/de.msg}'
    ('uplevel' body line 1)
    invoked from within
'uplevel 1
  1. '
        (procedure '::msgcat::mcload' line 10)
        invoked from within
    '::msgcat::mcload $msg_directory'
        (procedure '::b3d::L10n::SetLocale' line 14)
        invoked from within
    '::b3d::L10n::SetLocale '''
        (in namespace eval '::' script line 4)
        invoked from within
    '# Compiled -- no source code available
    error 'called a copy of a compiled script''
        invoked from within
    'tbcload::bceval {
    TclPro ByteCode 2 0 1.7 8.5
    14 0 132 24 2 0 84 1 4 14 14 -1 -1
    132
    f!!!!#-<<!+f+pv+K&s!*V!S7&-<<!)9N<!3fAs!5v!!!C!!!!gF#!!)`vpv1l8X!...'
        (file 'C:/Program Files/Altair/14.0/hm/scripts/BasicFEA/main.tbc' line 13)
        invoked from within
    'source $rootname.tbc'
        (in namespace eval '::UserProfiles::BasicFEA' script line 7)
        invoked from within
        (procedure '::hwt::SourceFile' line 1)
        invoked from within
    '::hwt::SourceFile $path3/BasicFEA/main.tcl'
        (procedure '::UserProfiles::BasicFEA::PanelProc' line 47)
        invoked from within
The secound error appears when executing the program funktion Linear static Loadsteps:
invalid command name '::b3d::loadstep::CreateSubcase'
    while executing
'::b3d::loadstep::CreateSubcase {Linear static}'
    ('eval' body line 1)
    invoked from within
    (procedure '::hwt::menuItemSelect' line 1)
    invoked from within
'::hwt::menuItemSelect ._Tb_BasicFEATB.f70.menu70 0 ::b3d::loadstep::CreateSubcase 'Linear static''
    (menu invoke)
Kind regarts
Franco
1 - 2 of 21
