During modal analysis under pressure and fluid structure interaction i got below error
*** ERROR # 2310 *** in the input data: MFLUID card must be used above the first SUBCASE.
can anyone please help with this.
Hi @viketh
Can you share the model file, please?
Please use the file transfer link in my signature to share the model file
During modal analysis under pressure and fluid structure interaction i got below error *** ERROR # 2310 *** in the input data: MFLUID card must be used above the first SUBCASE. can anyone please help with this.
I'm also getting same error message.
Could you please share the .out file of the run?
I want to solve bolt pretension as a subcase 1 and normal mode shape with bolt pretension as a subcase 2. Please refer attached file.fem
Following error message getting from optistruct (Mfluid).
1) Error # 2310 - Mfluid card must be used above the first subcase.
2) Fatal error # 5255 - the number of wetted element for virtual mass exceeds the current maximum allowed with VMOPT, 1. (This error got after removal of bolt pretension subcase.)
Please remove the Mfluid from the subcase for modal analysis and reference it using the GLOBAL_CASE_CONTROL card (Mfluid).
Sir,
1) Mfluid not available in global_case_control card. (Under Optistruct user profile).
2) How to increase allowable number of elements in VMOPT, 1. (Fatal error #5255)
I see you are using 14.0 version which is bit old and missing some key features.I ran shared file in latest version 2019 and it run fine with above suggested changes.
Yes I'm using 14.0 version.
Hi, I want to solve bolt pretension as a subcase 1 and normal mode shape with bolt pretension as a subcase 2. Please refer attached file.fem Following error message getting from optistruct (Mfluid). 1) Error # 2310 - Mfluid card must be used above the first subcase. 2) Fatal error # 5255 - the number of wetted element for virtual mass exceeds the current maximum allowed with VMOPT, 1. (This error got after removal of bolt pretension subcase.)
How to simulate rolling and pitching effect. Rolling 10 degree for 5 sec and pitch 30 degree for 10 sec.
