Grouping freezes Studio and the only way to continue is to exit and start again.
Actually right click on construction history list does not work at all. For example it is not possible to rename parts.
Hi Ari,
I tried grouping and it works fine here.Is there any specific procedure or situation to reproduce it?
Antonio
About the right click on construction history,that is not implemented at all.
The right click only works in the world browser,and there is no rename function there.
In order to rename an object you just need do click on itin the browser and then click again to edit the name.
About the right click on construction history,that is not implemented at all. The right click only works in the world browser,and there is no rename function there. In order to rename an object you just need do click on itin the browser and then click again to edit the name. Antonio
Hi Antonio,
The problem was the file. I had probably too many elements and it took minutes for the menu to appear.
I was modeling a speaker grill with 2900 holes.
Thanks anyway.
